Hi, I'm modeling a joint between a beam element and a rigid element. For this I used the MPC to connect the beam end and the rigid center node, in order to use this connection in different loadsteps. But the behavior of the nodes on the results is like they are disconnected.
Is there another way to simulate this?
All help is greatelly appreciated.
Thanks!
