Hi Im doing a project on aluminum energy absorbers and i need to do a quasi static analysis on my designed aluminum honeycomb. Basically a compression test. Im trying to do it in RADIOSS but have a few doubts.
1. Since it is a metal that is aluminum what mat law to choose is it 36 or 1 or 28(for honeycomb but i dont have the required curves, it is for foam right?mine is metal<?xml version="1.0" encoding="UTF-8"?>
2. I have to give contact between the honeycomb and the two anvils that is top and bottom. What type of contact should i give?
3. I have created one rigid body body that is is the top anvil to give it imposed displacement. The bottom anvil i fixed.
4. And my total displacement is 23mm and the time taken was 46 mins at a rate of 0.5mm/min in the physical test in the utm.
5. Im trying to replicate this compression to get Force vs deflection graph and energy absorbed.
Im attaching the pictures of my model and also my hm file.
