HI,
There seems to be so many card images in hypermesh. How to choose appropriate card images for a particular type of analysis. How will we know which Card image signifies what. Is there any link which helps me in this regard
Thanks
Bharat
If you go through the help files you can find a list of the different card images depending on which sort of cards you are after. The main page for each section (material, property, load etc) has a description of what each card is for and if you follow the link, it will provide more detailed information about what all of the parameters in each card signifies.
Card Images are always solver dependent and let you enter in the syntax of your solver 'values' (e.g. materail properties, schell thicknesses, etc.) A basic knowledge of the sysntax of your used solver will help selecting the appropriate card image.
Stefan
