I get an error message while running my optimization in optistruct.
I am optimizing an explicit model using equivalent static load method (ESLM). This method is integrated into Optistruct therefore one can also perform non-linear optimization.
Although I have enough resources in my computer I am getting an error message #151. It says:
*** ERROR # 151 ***
Error accessing the scratch files:
error encountered in subroutine 'xdslsv'
Solver error no. = -702
index = 1
This may be caused by insufficient disk space or some other
system resource related limitations.
(e.g. The Operating System or NFS cannot handle file size > 2 GB.)
This error was detected in subroutine prepslv4.
and another error message at the end of the out file:
***** ERROR ENCOUNTERED BEFORE COMPLETING THE CHECK RUN *****
Current Memory (RAM) : 3754 MB
Estimated Minimum Memory (RAM) for the check run : 227 MB
This error occurs in module 'prpdrv'.
Delete bootstrap file C:/......./CONVERTIBLE_OPTISTRUCT_SUBMODEL1.OS_dump_scr.bin
RESOURCE USAGE INFORMATION
MAXIMUM MEMORY USED 3754 MB
MAXIMUM DISK SPACE USED 0 MB
Can anyone had the similar problem and found the solution? Please help me.
Emrah Tokyürek
