Hallo,
I got the following error massage after starting a topology optimization.
WARNING:
The amount of memory that has been allocated is 3964 MB,
which is less than the required 11579 MB for completing the run,
using the minimum core processing in the solver.
A fatal error has been detected during input processing:
*** ERROR # 7007 ***
The run failed because automatic memory expansion has failed.
Currently allocated working storage is 3964 MB.
Automatic expansion failed to expand to 11579 MB.
The failed amount is the minimum required memory to complete the run.
Please verify whether the system has enough memory and rerun the problem.
I changed the “memory options” from “memory default” to “upper limit in Mb (= 1880)”.
Is it a hardware problem or is there an option to fix that error?
Thanks a lot in advance!
Sven
