Compliance Response
Altair Forum User
Altair Forum User
When I set my objective in a topology optimization to minimum compliance, what does that mean?  I assume it means to maximize stiffness, but where at on the object?  Is it the overall structure or just points where forces are applied?  If you know mathimatically what its calculating, that would help.
Thanks
-Dave
  • Altair Forum User
    Altair Forum User
    edited September 2014
    Hi Dave,
    you are right, miminum compliance means maximizing the stiffness of the structure.
    It could be for the entire structure of individual components, depending on how you define while creating responses.
    Compliance can be defined as C= 1/2*(F^2T)/K^T where C is compliance, F is applied force and K is the stiffness of the component or structure.
    Since the applied forces are constant your FE model, now you can say that F is constant throughout.
    This means C is inversely proportional to Stiffness of the component or structure. So, in order to increase the stiffness C has to be decreased.
  • Merula_20758
    Merula_20758 Altair Community Member
    Keep in mind that this is only valid for 'force controlled' loadcases. If you have a SPC defining an enforced displacement, then you want to maximize the compliance for maximizing the stiffness.
    Seen here:
    http://www.trinity-eng.co.kr/ez/pdf/OptiStruct01.pdf
    Merula
  • Altair Forum User
    Altair Forum User
    edited October 2015
    I do not grasp why the formula reads C = (1/2) F2 (1/K).
    Why is the force squared?
    Also in the document of the last post, it says C = FT U, which makes more sense to me.
    Can anyone help on deriving the above-mentioned equation for C, C = (1/2) F2 (1/K)?
    Kind regards,
    Robbin
  • Altair Forum User
    Altair Forum User
    edited October 2015
    Hi Robbin,
    That was a typo error. It should be C= 1/2*(F^2T)/K^T
    Compliance is equal to 1/2*(U^T)*F and F= K*U. If you replace U with F/K in the compliance equation, you will end up with F sqaured and powered with T
  • Altair Forum User
    Altair Forum User
    edited October 2015
    Thanks Prakash. I also found it in the Optistruct User's Guide, it makes sense now image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
  • Altair Forum User
    Altair Forum User
    edited October 2016
    Seen here:
    Merula
    Hello Merula,
    I know it has been two years you posted this message, but by any chance would you (or anyone else reading this) still have that file (http://www.trinity-eng.co.kr/ez/pdf/OptiStruct01.pdf) ? It seems the link doesn't work anymore.
    Also I am really interested in learning more in depth about the difference between 'force controlled'  or 'enforced displacement controlled' load case and how the solver considers both cases. I tried to search a bit in Optistruct documentation but haven't found anything that talks about it.
    Thank you!
