Hello. How can i create a rigid Body previously meshing. I have create the Cylinder with the surcafes Panel. I have problem to get this surface as a rigid. I have uploaded a pic of it.
Thanks.
Osman,
Which solver do you need to create the cylindrical rigid wall for?
See step 8 here to do this for RADIOSS
Altair RADIOSS > RADIOSS Tutorials and Examples > Tutorials > Large Displacement Finite Element Analysis > HyperMesh:
RD-3550: Simplified Car Pole Impact
Hello Rahul,
I use Radioss (bulk data format). My task is to simulate a composite plate that bend over a rigid cylinder. But the cylinder must not deform and move.
Thanks for you help.
Osman
I see that you can use the RWALL card, see - Altair OptiStruct > Reference Guide > Input Data > Bulk Data Section > RWALL
This can be created from Analysis > rigid wall within HyperMesh.
See - HyperWorks Desktop Applications > HyperMesh > User's Guide > HyperMesh Panels > HyperMesh Panels Listed Alphabetically:
Rigid Walls Panel
