Pressure not uniform
Altair Forum User
Altair Forum User
Hi Guys,
I am a ph.d student of Mechanical Engineering at the University of Florence and am doing HyperMesh analysis on a pump.
I've to set a pressure proportional to the radius of the impeller.
Do you know how can I set a not uniform pressures' field?
Thanks!
Lorenzo
  • mvass
    mvass Altair Community Member
    edited June 2011
    Try:
    BCs-->Create-->Pressures click the arrow (pull down menu) next to 'magnitude' and select 'equation'. Select your elements (where the pressure field will be applied) and the orientation axis.
    Alternative: Create a tab seperated .txt file of the form: X Y Z (pressure value) where X, Y, Z are coordinates, select your elements and instead of 'equation' select 'linear interpolation'. Select your .txt file and click create
    Hope this helps
  • Altair Forum User
    Altair Forum User
    edited June 2011
    It works!
    Thank you very much.
Welcome!
Welcome!
