How to Import CSV or EXcel data to Hyper Graph?
Hi Pradeep,
You can directly open the .csv in HyperGraph.
thanks Sir, only csv is supporting?
Please go through the file attached which is a list of supported files in HyperGraph.
Hi @George P Johnson
Could you please let me know hot to view the energy and load Vs displacement curve in Hyperview from the Optistrct analysis ?
Please refer video for cross plot functionality in HyperGraph for Force Vs Displacement plot.
Hi @Rahul R
Thanks for your reply.
I am new to optistrct. In LS dyna we ll have GLSTAT,MATSUM and RCFORCE to measure the energy and forces in Graphical view.
Same as Ls dyna which on which output file we need to check in the Hyperview ?
Hi @jsk459
Can you share details about analysis?
Is it explicit or implicit?
If it is a geometric nonlinear analysis (EXPDYN only) you can add XHIST or instead you can use RADIOSS which is another solver from Altair for Explicit dynamic analysis.
Hi Prakash,
It is an Quasi static non linear analysis
I don't think it is possible to output total energy with NLSTAT (small or large displacement)
Instead, use RADIOSS implicit where you can request using Blocks.
