Part Volume
Altair Forum User
Altair Forum User
How can we find a part volume in hypermesh? Is there any direct option as in PRO-E or we should find it manually? Could you please suggest me...
I appreciate your help.....
  • Altair Forum User
    Altair Forum User
    edited February 2015
    Sry i found the option to caluculate the volume. Tools> masscalc
  • Altair Forum User
    Altair Forum User
    Hi Bhavana,
    Tool page>> Mass calc>> select component and click calculate.
    You should  see Mass, volume and area.
  • Altair Forum User
    Altair Forum User
    Prakash,
    Can we create the part geometry from elements. Because i have rad file which doesnt have geometry.
    Bhavana.
  • Altair Forum User
    Altair Forum User
    Yes,
    Use From FE option in Geom>> Surfaces which extracts surface(S) from elements.
  • Altair Forum User
    Altair Forum User
    Thanks Prakash,
    The geometry is created but not within the component. It created in faces component. Cant we have the geometry in the same component in which we have mesh.
  • Altair Forum User
    Altair Forum User
    Bhavana,
    Make sure you have activated the 'Split by Components' option to have surface or geometry in same component as mesh.
  • Altair Forum User
    Altair Forum User
    Yes the option was activated. When iam creating the surface, the elemens were not selected so i have extracted the faces for that component and made the meshed component current. Then i have created surface, it created in faces component.
  • Altair Forum User
    Altair Forum User
    Bhavana,
    In such case you have to organize face elements of solid elements in their respective components and extract the surface.
  • Altair Forum User
    Altair Forum User
    FYI,
    the below macro may be something useful for you.
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-25220900-1423654494_thumb.jp
  • Altair Forum User
    Altair Forum User
    yes i have tried doing that. while creating faces i made the meshed component as current and found faces. But again faces were created in seperate component.
  • Altair Forum User
    Altair Forum User
    Bhavana,
    when you extract faces, a new compoenent will be created and shell elements will be organized into that component.
    Use the script which I have mentioned in my previous post which may help you when extracting faces.
  • Altair Forum User
    Altair Forum User
    Thanks Prakash,
    But how can i download the script?
  • Altair Forum User
    Altair Forum User
    Hi Prakash,
    Please suggest me how to apply or where can i get that script?
    Bhavana.
  • Altair Forum User
    Altair Forum User
    Hi Bhavana,
    Use the link below which will redirect you to script exchange. Please login and search for '292' which is the script ID.
    http://www.altairhyperworks.com/Script-Exchange.aspx??top_nav_str=1
  • Altair Forum User
    Altair Forum User
    Prakash,
    I have downloaded the tcl script, how to use this?
  • Altair Forum User
    Altair Forum User
    File Menu>> Run>> Tcl/Tk
  • Altair Forum User
    Altair Forum User
    Prakash,
    The Tcl script has created faces for the selected component as a different component which we can do by tools>faces. But i need to create a geometry for the meshed component with in the component.
    For example 'rod' is my component which i have only elements in rod but doesnt have geometry. when we run the tcl file, it will ask to select the component. After selecting rod, it created rod_shell another component which consists of faces. But i need to create face elements in rod component so that i can select those elements while extracting geometry.
    Please suggest me if we have any tcl script to create faces with in the selected component or can we merge two components among which one has elements and the other has geometry?
  • Altair Forum User
    Altair Forum User
    Bhavana,
    I dont see a way to directly organize surfaces to their respective solid element components.
    The TCL will allow you to extract faces and organize them with component name followed by SHELL.  You can organize the surfaces into parent components using Organize panel (Shift+F11).
  • Altair Forum User
    Altair Forum User
    Yes it worked..... image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    Thanks for your timely help prakash
