Hi, i am a new member here and i have a question about HW Optistruct.
At first, my Example is a tool for injection moulding. I want to optimize it. My Goal is to minimize the mass.
I think i explain my process respectively the way i build my model.
-> Import geometry
-> make 2 components 1) Design & 2) Non-Design
-> define material
-> define property for 1) & 2) with PSOLID
-> Assign property to components
-> Mesh geometry
-> subdivide elements into design and Non-Design ... with Keep in mind that component is make current
-> create two load collectors ---------> Pressure & SPC ( all dof´s are checked because the mould is in a Frame )
-> create loadstep --> type linear static ( Pressure (Load) and Non-Design (Component) were current on Load collector , i dont know if it cares ?)
-> define desvar ---> 'design' assign prop -> design & choose PSOLID ( the component design was make current now)
-> define Response --> Name volfrac ---> choose responsetype volumefrac
-> objective min Response=volfrac
after that i start the optimization and get an ERROR 2502 see at Picture below
but my other Problem was , ERROR 332? i forgot the number but they told me that the compliance was too high or so
i hope someone can help me
