Hi
I am wondering is there a way to change the legend text? Please see attached pic.
you have to change the name of the curve...
Mario
Hi Mario,
But if the name of the curve changes, the legend will be the same as it is. I want to change those two names as 100mm/s and 200mm/s respectively. Is this possible?
the names in the legends are the names of the curves. You have to change the names of the curves !!!
Click on the icon 'Define Curves' and change the name in the top field. Press enter...
But, how to change legend after use Label Prefix in advanced plot options? Also how to change page name and (or) hide name without creating new and delete old page?
