Rupture of composite laminates
and i am not able to see 3D representation of ply thickness, orientation when i do FE modeling for Radioss
0 -
HI Rahul,
In RADIOSS it is not possible to visualize the plies as can be seen in OptiStruct.
There are few failure models available (/FAIL) for composite. Please refer to those models.
0 -
Thank you so much.
0 -
Altair Forum User said:0
how can i see Strain energy in hyperview?
0 -
Hi Rahul,
You can output Strain energy using Control cards>>ENG_ANIM_ELEM>> EPSP.
0 -
thank you/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
0 -
It is working now. But still it is not giving option to see strain energy in hyperview
0 -
Hello prakash,
i have created my composite plate using- Material: M25_COMPSH and Property: P11_SH_SANWD
now i have to use PUCK criteria for impact analysis. where i should define or assign FAIL/PUCK?
0 -
Rahul,
Create a property with type as FAIL/PUCK.
I will get back to you with Strain energy soon.
0 -
ok but in addition i have to define plies using Material: M25_COMPSH and Property: P11_SH_SANW.
so my question is how can i use both the properties-- P11_SH_SANDW and FAIL/PUCK for same component
0 -
Hello Prakash
will you please reply to my above question?
0 -
Hi Rahul,
Introduce the /FAIL/PUCK property and refer the material in the new card.
0 -
ok i will do it
0 -
I am not getting how to assign FAIL/PUCK.
Please help me.
0 -
i will try one more time and then i will get back to u
0 -
i am not getting
0 -
Rahul,
can you share the .out file?
0 -
can you check the Tau Max value?
Normal value of Tau Max is 10 times higher than the actual times step should be set in the card directly.
0 -
that's okay. but i am struggling to introduce FAIL/PUCK property. I am not able to assign it to component 'XYZ'. i hve already defined comp. 'XYZ' using Material: M25_COMPSH and Property: P11_SH_SANW.
0 -
Rahul,
you dont need to assign to any component. Refer the M25 material in the fail/puck property
0 -
okay thank you. i will run it
0 -
And ruptured elements are getting deleted. is there any way to stop it?
0 -
Hi Prakash
You are supposed to tell me about strain energy?
0 -
Hi Prakash
0 -
Rahul,
I am checking with experts on how to output strain energy for composites. I will get back to you soon on this /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
0 -
okay i will wait
0 -
You can get the output in animation file with /ANIM/ELEM/EPSP
For Law25 this output is plastic strain energy. It is equal to zero when the material is elastic
0 -
Sorry here EPSP gives the plastic work.
