I have several scripts which use this command:
*createlistpanel nodes 1 'Select independant nodes';
In each instance I usually want to select nodes 'by path'. Is their any way to have the list selection panel open with the selector set to 'by path' (it defaults to 'node list').
I am working in Hypermesh v10 on Linux.
Thanks,
Paul
