Hello
I have some inquiry about solidThinking 8.5.
Attached are some errors I found after some tests.
let me know please...
In the first example this is not necessarily a problem with the geometry. You can increase the view detail to reduce some of the visual imperfections and increase the surface tessellation. This is different from the actual surface geometry. The best way to check is to use the Tolerance Check tool on this object to see if there are really gaps in the geometry.
For the second example you can also try exporting the model as an IGES or STEP file.
Thanks,
-Darren
thank you so much, I solved the problem by your help
