TCL / saving ONLY the properties
Altair Forum User
Altair Forum User
I am new in HyperMesh and Macros, so i'll try to do explain myself the best way i can.
I have a model with a certain quantity of properties ( a lot... named PSHELL_$nbrID ) and I would like to save those properties in a independent file.
Meaning I want only this in my file :
PSHELL 2 1 2. 1 1
PSHELL 3 1 2. 1 1
PSHELL 4 1 2. 1 1
PSHELL 5 1 2. 1 1
PSHELL 6 1 2. 1 1
PSHELL 7 1 2. 1 1
PSHELL 8 1 2. 1 1
I can't reach this result for now ! I still have the DVGRID/CQUAD4/PLOADS and other cards getting included in my file !
Someone has a tip/idea/solution ?
Thanks a lot in advance !
Clément
Welcome!
  • Altair Forum User
    Altair Forum User
    edited May 2012
    Clément,
    have you reviewed this script, http://www.altairhyperworks.com/Macros_Exchange_Preview.aspx?macro_id=436 ? I think this is what you need or you may modify it.
  • Altair Forum User
    Altair Forum User
    edited May 2012
    Another option is to create a copy of the solver template (NASTRAN or Optistruct) and remove all the other output types. When you export the model using this template, it will only write out property cards. It will probably flag a warning message that types of some entities are not supported.
  • Altair Forum User
    Altair Forum User
    edited June 2012
    Thanks to both of you for your answer.
    Etg's solutions seems more simple to implement...
    I am going to try both to see
    Thanks again
  • Altair Forum User
    Altair Forum User
    edited June 2012
    A lot of lines do delete image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    the file had 65000 lines and for now has 26000 lines
    some errors, but it seems to work...
    A very brut and rought method !
  • Altair Forum User
    Altair Forum User
    edited June 2012
    Export Option 'Custom' and selecting only 'Property' should work as well.
    Regards
  • Altair Forum User
    Altair Forum User
    edited June 2012
    Yes i tried this, and then looking in the script window to see the code doing that
    but it did not work, when i save i still get other stuff than PSHELLs...don't know why
  • Altair Forum User
    Altair Forum User
    edited June 2012
    I do what HETTEL commented and also at the export panel, I un-check 'Write HM comments'.
Welcome!
Welcome!
