output request (Angular velocity) in motion view
Altair Forum User
Altair Forum User
Hi there,
How to give output request to find the angular velocity of a link at a certain point in motion view
Here I have considered a very simple Slider crank mechanism (see attached image), I was applied a velocity as input on the slider.
For this input velocity, I want to check the angular velocity of the crank.
Thank in advance  image/emoticons/default_smile.png' alt=':)' srcset='<fileStore.core_Emoticons>/emoticons/smile@2x.png 2x' width='20' height='20'>
<?xml version="1.0" encoding="UTF-8"?>post-9665-0-95194000-1387462391_thumb.pn
  • Altair Forum User
    Altair Forum User
    edited June 2014
    Hi Ravi Teja,
    You can use function WX ,Wy, WZ to output angular velocity from MotionView/MotionSolve.
    in the output panel, change the property type to expression and write an expression of the type WY(I, J, K) This outputs the rotational velocity about Y axis.
    Please refer to Help documents for more information image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
  • Altair Forum User
    Altair Forum User
    edited November 2018
    Hi ,
    How can I generate speed plots in motion view.
    Kindly suggest.
    Thanks
    Sunil
Welcome!
Welcome!
