i am looking for help with the ' *** ERROR # 1728 *** in the input data: Incorrect SET definition. '.
Why it doesnt run?
Thx for help
I'm getting the same error...
Hi @RodrigoFST
Not sure what is causing the error. Can you share the model file and .out file using the File transfer link available in my signature?
Hi @Prakash Pagadala
I shared the model and the .out file with you. Thanks for the help.
Hi @RodrigoFST The Node set ID 3 has no nodes in it. Can you please check what this is created for?
If the set is not necessary or empty, you can delete and proceed.
Apart from that I noticed few plies which does not refer to any elements, element sets or surfaces like PLY with ID 4, 5 etc... Please check this and update.
I can run the analysis now. Thanks a lot!
