Hi all
I have used a few zero length cbush elements to represent bolts but came across the following error:
*** ERROR # 40 ***CBUSH # xxxxx has zero length.
Is there a way to fix this problem?
Thanks!
did you set CID?
if bush has zero length, its x-direction must be specified from the CID
reference to manual please, it's great
