I'm getting the following errors everytime I try to run an optimization. I'm using a relatively fine mesh, for fidelity purposes and hope I don't need to make it more course. Is there any way to take care of this?
*** ERROR # 7007 ***
The run failed because automatic memory expansion has failed.
Currently allocated working storage is 6654 MB.
Automatic expansion failed to expand to 7620 MB.
More than the failed amount of memory is required to complete the run.
Please verify whether the system has enough memory and rerun the problem.
***** NOT ENOUGH MEMORY TO COMPLETE THE CHECK RUN *****
Current Memory (RAM) : 6654 MB
Estimated Minimum Memory (RAM) for the check run : 8231 MB
*** ERROR # 7001 ***
Not enough memory for preprocessing
(total number of nonzero terms has not been determined)
Please see the previous error message for more information.
This error occurs in module 'prpdrv'.
RESOURCE USAGE INFORMATION
MAXIMUM MEMORY USED 6654 MB
MAXIMUM DISK SPACE USED 1 MB
