hi
i am trying to do a basic linear static analysis in 3d models.
when i send the model to solver, analysis completed but in hyperview one model is shown flat and not true.
Why is the model shown wrong
When i make the contact 'freeze', i can take results,
but when make slide or stick, the model is making flat and give wrong results
When i make the contact 'freeze', i can take results, but when make slide or stick, the model is making flat and give wrong results
maybe your contact is not working truely and this results some unconstrained boundary conditions and your analysis blow up.
in your contact region there must be enough nodes between each surface for a good contact.
