MEMORY ESTIMATION INFORMATION :
Solver Type is: Sparse-Matrix Solver
Direct Method
Current Memory (RAM) : 41148 MB
Estimated Minimum Memory (RAM) for Out of Core Solution : 41135 MB
Recommended Memory (RAM) for Out of Core Solution : 41148 MB
Recommended Memory (RAM) for In-Core Solution : 438587 MB
(Note: The Minimum Memory Requirement is limited by Output Module.)
DISK SPACE ESTIMATION INFORMATION :
Estimated Disk Space for Output Data Files : 10808 MB
Estimated Scratch Disk Space for In-Core Solution : 23721 MB
Estimated Scratch Disk Space for Out of Core Solution : 546652 MB
BEGINNING ANALYSIS SOLUTION ....
ANALYSIS RESULTS :
*** WARNING # 1971
Current run is likely to fail due to insufficient disk space.
Estimated disk space requirement = 557460 MB
Estimated disk space available = 184013 MB
Suggestions to reduce disk space requirements:
For static analysis - reduce the number of loadcases.
For eigenvalue/buckling analysis - reduce frequency range in
EIGRL card or number of modes requested.
For FRF analysis - reduce the number of loading frequencies.
For transient analysis - reduce the number of output time steps.
ITERATION 0
*** ERROR # 2005 ***
WIN_IO: WriteFile failed. (112).
*** WARNING # 732
Nonzero iostat returned from access write.
File's unit number = 41
Record number = 167292
Buffer size = 131072
Access option = 2
Returned iostat = -3
*** WARNING # 732
Record number = 167293
Access option = 2
*** WARNING # 732
Record number = 167294
Access option = 2
*** WARNING # 732
Record number = 167295
Access option = 2
*** WARNING # 732
Record number = 167296
Access option = 2
*** WARNING # 732
Record number = 167297
Access option = 2
*** WARNING # 732
Record number = 167298
Access option = 2
*** WARNING # 732
Record number = 167299
Access option = 2
*** WARNING # 732
Record number = 167300
Access option = 2
*** WARNING # 732
Record number = 167301
Access option = 2
*** More of ERROR messages # 2005 were suppressed...
Too many error messages. Aborting run.
Current limit is 10000. Use 'MSGLMT' control card to change this value.
Following warning messages appeared too many times
and were suppressed:
2005
Total of 9989 repeat error message(s) were suppressed.
To see more messages use 'MSGLMT' control card in the data or config file.
There were 11 WARNING(s) reported during the run.
