I'm new using the HyperWorks environment and I have the following error message:
Here goes the .out file.
I see there are few warning messages in starter file.
Can you share the complete .out file for Engine?
That's supposed to be my full .out file. I see that I need to investigate the software a little better before coming here for questions.
Thank you.
Looks like there is some error in your engine file.
could you please share the model file?
i am facing the same error
wt should i do?
Hi Rahul,
share the entire engine .out file.
hi Prakash
below i hv attached required file
i am going to use fail/puck criteria and according to that i will change material properties but before that i wanna know how to see strain energy in hyperview for each ply?
I need the .out for engine. What you have shared is for starter deck.
Share Impact_analysis_on_composite_laminates_1_0001.out
Hi Prakash,
do you mean this file...
It has generated only files in the below image.
Rahul,
Can you share the model?
Prakash
i have attached HM file
Uncheck 'FAIL' in ANIM_ELEM engine card and run the analysis.
ok
Thank you prakash. It is working now. But still it is not giving option to see strain energy in hyperview
Can you add EPSP card in engine file?
