Different Mesh Type
Altair Forum User
Altair Forum User
Hello
I just downloaded the academic version of the program.
I want to mesh a part with different mesh type than the already existed. For example i want to provided the locations of the nodes of the finite element,
Can hyperworks provide that possiblity?
Thank you in advance
  • Altair Forum User
    Altair Forum User
    edited March 2015
    You need to read the manual and play with some tutorials image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
  • Altair Forum User
    Altair Forum User
    edited March 2015
    @chrisrek: You can found alot of doc/tuto on Altair site. See my screenshot.
    <?xml version="1.0" encoding="UTF-8"?>post-889-0-69528300-1426849203_thumb.png
  • Fady Farouk
    Fady Farouk Altair Community Member
    edited February 2016
    Hello guys, i have been trying to mesh several objects for the past few days.
     Everytime, it all goes correctly, even the meshing, loads, responses, and when i assign the properties it says 'elements assigned'.
     Now when i run the topology, it says job terminated at 'Element Quality Check - element xxxx invalid element type'.
     It does this almost everytime - no matter the component.
     I try remeshing, and activated the 'REMESH' from 'opticontrol', i auto clean the geometry before meshing - same outcome.
     When i try to clean mesh elements it says 'unable to create hmshell.
    Is there anyway i can bypass the element QI check?
    I always use Volume Tetramesh - PSOLID
    i can't fix all the broken elements manually.
    Please advise as this has been really delaying.
    Note: i have student edition so i cannot have more than 10,000 elements.
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    Could you share us the .out file of the run?
    Regards
    Rahul R
