Optistruct Static analysis is taking long time to solve
Altair Forum User
Altair Forum User
Hi All,
Please help me out for solving OptiStruct linear static analysis.
Problem: Since from 35hours solver is running but no result.
Already written 520GB size scratch file, till increasing. Taking all 32GB ram and 8 core. I have HW 50 tokens.
Out file is:
FINITE ELEMENT MODEL DATA INFORMATION :
  Total # of Grids (Structural)        :   1654487
  Total # of Elements Excluding Contact:   1173042
  Total # of N2S Contact Elements      :    434140 (internally created CGAPG)
  Total # of Rigid Elements            :    222519
  Total # of Rigid Element Constraints :   2059857
  Total # of Local Coordinate Systems  :         1
  Total # of Degrees of Freedom        :   9926916
  Total # of Non-zero Stiffness Terms  : 267537486
  Element Type Information
   CONM2    Elements   :       51
   CQUAD4   Elements   :  1169800
   CTRIA3   Elements   :     3191
  Load and Boundary Information
   FORCE Sets        :         1
   SPC   Sets        :         1
  Material and Property Information
   PSHELL Cards      :        16
   MAT1   Cards      :         1
OPTIMIZATION PROBLEM PARAMETERS :
 NO DESIGN MATERIAL OR DESIGN VARIABLES FOUND  : ANALYSIS ONLY
   Static Subcase Summary :
   Subcase ID    SPC ID   FORCE ID
        1            4            3
   Run Type                        :   Analysis Only
   Scratch file directory          : ./
                                     Free space:   740.308 GB
   Number of CPU processors        :          8
MEMORY ESTIMATION INFORMATION :
 Solver Type is:  Sparse-Matrix Solver
                  Direct Method
 Current Memory (RAM)                                    :    5484 MB
   In addition a ramdisk area was allocated in memory    :     200 MB
 Estimated Minimum Memory (RAM) for Minimum Core Solution:    5251 MB
 Recommended Memory (RAM) for Minimum Core Solution      :    5251 MB
 Estimated Minimum Memory (RAM) for Out of Core Solution :    8782 MB
 Recommended Memory (RAM) for Out of Core Solution       :    9785 MB
 Recommended Memory (RAM) for In-Core Solution           :   58386 MB
 (Note: Minimum Core Solution Process is Activated.)
 (Note: The Minimum Memory Requirement is limited by Assembly Module.)
 (Note: Use param,HASHASSM,yes to avoid assembly module memory bottleneck)
DISK SPACE ESTIMATION INFORMATION :
 Estimated Disk Space for Output Data Files              :     648 MB
 Estimated Scratch Disk Space for In-Core Solution       :    9103 MB
 Estimated Scratch Disk Space for Out of Core Solution   :   74786 MB
 Estimated Scratch Disk Space for Minimum Core Solution  :   79320 MB
BEGINNING ANALYSIS SOLUTION ....
ANALYSIS RESULTS :
ITERATION   0
System Config:
 **         Windows 7 Workstation  SP1 (Build 7601)  DELL01-PC         **
 **          8 CPU:  Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz           **
 **                        CPU speed  3400 MHz                         **
 **                    28696 MB RAM,  65418 MB swap                    **
Please help me whether I have to wait for run. if yes please suggest me approximate time it may take.
Thanks and Regards,
Shriram S Kalburgi
Welcome!
  • Altair Forum User
    Altair Forum User
    edited March 2016
    Hi Shriram,
    One of our Support Engineers from INDIA will get in touch with you soon.
  • Altair Forum User
    Altair Forum User
    edited March 2016
    Thank you Prakash.
  • Altair Forum User
    Altair Forum User
    edited March 2016
    Have a look at this line:
    So your 32G of Ram is NOT enough for in-core solution. Memory is so cheap. Add more Ram to make your life easier :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
  • Altair Forum User
    Altair Forum User
    edited March 2016
    Thank you Q.NGUYEN-DAI,
    I will check the possibility.
    Is there any other option, so that I can solve my problem.?
    Thank you.
  • Altair Forum User
    Altair Forum User
    edited March 2016
    32GB full RAM is utilising but CPU is 1% to 15% not the full.
    Shriram
Welcome!
Welcome!
