Is there an easy way to apply pressures to elements when there is a varying load across the surface.? Right now, I have to select which elements I want for a given magnitude to apply the pressure, as well as nodes for the normal face. This is extremely time consuming considering I'm running multiple different cases. Additionally, if I remesh or open a new model, I have to do the same process over. If there was a way to copy a load from a different model or import a spreadsheet that would be awesome and save me a ton of time.
Thanks
-Dave
