I have created a rubber material with pbush1D.
I need to apply a displacement on element/ node instead of force for running a static analysis.
So how can I define displacement to the element/ node ?
try 'constraints' and set a non-zero value for the desired DOFs
So for running for analysis only spc should I call?
Is it enough for running the analysis?
i think yes
Jodha,
See - http://forum.altairhyperworks.com/index.php?/topic/13827-how-to-apply-displacements-as-bcs/?hl=%2Benforced+%2Bdisplacement#entry19852
and other forum topics on this.
