Hello Everyone!
I am using the nFX Tools in SimLab 2019.3 to create a simulation environment with SPH Particels.
What i want to realise:
I just have a cup filled with Oil. It is open on both sides and surrounded by Air and i want the Oil to run out of the cup downwards. To close the system there is a cover around the air volume.
I have defined three Materials, the two Fluids Air and Oil, and a Wall Material. The Material specalizsations can be seen in the attachment.
I created the three different sorts of Particels in three steps. First i sealed the cup to create the Oil Particels inside the cup and the Air Particels. Then i opened the cup again and created the Container Particels as Wall. Finally i have put these three together.
To realise that the Oil runs out of the cup downwards i have created a Domain 'Body Force'.
The problem now is, that during the simulation with nanoFluidX some Oil particels are getting through the Wall Material of the Cup but i Have no idea why. In the video attatched i have visualised the Velocity and the Oil (grey). The cup is not visualized there. These particels are like shooted out of the cup.
I have also attatched an STL Model oft the cup and the cover. They are one model.
Does anyone have an idea what the problem is or what i am doing wrong?
Thanks a lot!
/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
