Hello All,
I am running a Non Linear Optimization with the following load conditions:
STEP-1
Assembly fit using PCONT clearance
Pretension
STEP-2
Temperature change from 23 degres to -40 degrees
Non linear optistruct run was clear but when I run the model for optimization I get the following error:
*** ERROR # 415 ***
Static Subcase 2 has 'STATSUB(PRETENS)' defined.
Optimization with compliance cannot be performed.
Any suggestions will be highly appreciated.
Thanks
Praveen
