Does anyone know how to create gap elements around a cylinder which is inserted into another part?
Thank you,
Soraya
If you want to create gap elements between nodes of two cylinders, best workaround is to use Spot welds>> GAP.
Hi Prakash,
Thank you for the help. But the spot can be either weld or gap. I can create the spot but I don't know how to use it for the gap elements.
I appreciate if you can give me some ideas about how to work with the spot.
Change the Type of weld to Gap as shown in the image below:
