Hi all,
I have problems with the definition of a nonlinear spring (PBUSHT) in combination with a TABLED1 entry.
In the attached example I expect a deflection of 2.2 mm, but I got 30 mm. It looks like only the first entry in TABLED1 is used and this stiffness will be extrapolated.
What is wrong in the input?
I suppose that I have to enter deflection as x and force as y in the TABLED1 entry.
Andreas
$$ Optistruct Input Deck Generated by HyperMesh Version : 14.0.120.28
$$ Generated using HyperMesh-Optistruct Template Version : 14.0.120
$$ Template: optistruct
UNITS = SI
$HMNAME LOADSTEP 1'lc-01' 9
SUBCASE 1
LABEL lc-01
ANALYSIS NLSTAT
SPC = 1
LOAD = 2
NLPARM = 4
BEGIN BULK
GRID 2 50.0 0.0 0.0
GRID 6 50.0 -50.0 0.0
CBUSH 7 4 2 6 0.0 0.0 1.0
$HMMOVE 4
$ 7
$HMNAME COMP 4'bush_2'
$HWCOLOR COMP 4 21
$HMDPRP
$ 7
$HMNAME PROP 4'bush2' 2
$HWCOLOR PROP 4 11
PBUSH 4 K0.0 RIGID RIGID RIGID RIGID RIGID
PBUSHT 4 KN 5
SPC 1 2 123456 0.0
SPC 1 6 13456 0.0
$HMNAME LOADCOL 5'force_disp'
$HWCOLOR LOADCOL 5 21
TABLED1 5 LINEAR LINEAR
+ 0.0 0.0 1.0 1000.0 2.0 10000.0 3.0 1.0+8
+ ENDT
$HMNAME LOADCOL 4'nlparm'
$HWCOLOR LOADCOL 4 25
NLPARM 4 20 1 25
FORCE 2 6 01.0 0.0 30000.0 0.0
ENDDATA
