Hello eveyone,
currently i am doing Gearbox Simulations with you nanoFluidX Code. Now i am troubeling with the value of the 'reference length'. Normally the code is getting this value by itself but it is recommended that the user is giving this value manually. In the manual it says that for example the fluid hight in the gearbox should be this value. Is by this meant only the hight of the Oil in the Gearbox or is it the hight of the Oil plus the Air?
Thank you very much.
