Hallo,
I got the following error massage after starting a topology optimization.
*** Automatic resize FAILED !!!!
*** ERROR # 8030 ***
Request for more memory failed with data block name: lgnelshl.
EXCEEDED AVAILABLE SYSTEM MEMORY. Dynamic memory allocation failure.
It is possible that fixed memory run may succeed (option fixlen=X).
**** Error 8030 in datamr() during 'insert' operation.
Data block name 'lgnelshl'.
Current memory allocation 1883 MB,
Unused memory 1 MB,
Number of blocks: 163 used, 1 free.
Need at least 1218 MB free (1218 MB more than allocated).
A fatal error has been detected during input processing:
*** Run terminated because of error(s) in the input data.
I changed the “memory options” from “memory default” to “upper limit in Mb (= 4000)”.
Is it a hardware problem or is there an option to fix that error?
Thanks a lot in advance!
Sven
