FRF analysis ERROR # 151
Hi Prakash,
I am running a Direct FRF analysis in Optistruct. I have asked out on only 2 frequencies. I am attaching my .out and .stat file here and error message also. Please resolve my issue.
*** ERROR # 151 ***
Error accessing the scratch files:
error encountered in subroutine 'xzslvn'
Solver error no. = -410
index = 1
This may be caused by insufficient disk space or some other
system resource related limitations.
(e.g. The Operating System or NFS cannot handle file size > 2 GB.)
This error was detected in subroutine inptvmc.
**** ABORTING RUN DUE TO UNEXPECTED ERROR CONDITION ****
**** Job completed ****
Thanks
Hemanshu
Hi @hemanshu
Do you have read and write permissions on the machine which you are working on?
Try to assign a temporary directory to write and access scratch files using TEMPDIR. Go to ControlCards>>TEMPDIR and give the path.
0 -
Hi Prakash,
My solution requires estimated disk space of 1.1 TB for scratch files, and i have it in two drives as F drive - 900 GB, and E drive -300 GB.
I am able to assign one drive as tmpdir for scratch files as TMPDIR= FILESIZE=300, E:\TMP
When i am solving my file in F drive.
It is still showing that less space for scratch files. So i have aborted the run. I am attaching .out and .stat file also.
Is it possible to solve this model by this method or i need to assign two temp directories or something else.
Thanks,
Hemanshu
0 -
Hi Prakash,
Also i can not combine both drives as they are part of different hard drives on my workstation.
Thanks,
Hemanshu
0 -
Hi Hemanshu,
Can you check for which frequency it is taking more space?
Check if -fixlen command solves your problem. Follow few of these suggestions:
1) close all unnecceasy programs and application which utilize the machine memory
2) If possible cleaup diskspace
Meanwhile I will check if there a way to combine two directory for temporary usage.
0 -
Hi Prakash,
Thanks For the above suggestions. I have tried simulating my problem with above options, but was not able to solve it. Now i am trying to buy a new computer hard drive.
Thanks
Hemanshu
0 -
Thanks for the update Henamshu,
Let me know if you still have any problem after increasing the memory.
