when I realize my laminate it creates propertys with a PCOMPG Card Image.
What can I do when I want the laminates in PCOMPP?
And why it is better to use PCOMPP?
Best Regards
Marcel
Hi Macel,
Realizing laminate converts a ply based stack to zone based model.
are you using a student edition of HyperWorks?
In full suite of HyperMesh you have an option to convert PCOMP/PCOMP(G) to PCOMPP in Aerospace OptiStruct profile.
Please refer to the below Tip and Trick for more details.
http://www.altairuniversity.com/wp-content/uploads/2015/03/Convert-PCOMPG-to-PCOMPP.pdf
Hi Prakash,
yes I am using the student edition,but I have a license for the full suit.
Can I download the full version and put my license in.
Or will there some problems,because I used the license befor ?
Regards
Hi Prakash,Is it possible to realize the laminate the other way?I have PCOMPP card and I want to change it to PCOMPG?I tried using the same procedure but it does not work.
I am using Hypermesh v13.0.110.31Regards,Sanketh
Hi Sanketh,
Right click on Laminate and select Realize.
