While doing a pretension analysis and want to perform loading and unloading analysis with non-linear considerations.Below is how my loadsteps are structured.
Loadstep 1 - Pretension
SPC
NLPARM
PRETENSION LOAD
Loadstep 2 - LOAD1
SPC
LOAD1
NLPARM
Subcase Option:
CNTNLSUB - (Loadstep1)
Loadstep 3 - UNLOAD1
SPC
NLPARM
Subcase Option:
CNTNLSUB - (Loadstep2)
With this procedure only Loadstep1 is running and the run gets sopped. I have 2 questions here
Q1: Do I have to use STATSUB(PRETENS) along with CNTNLSUB in Loadstep2?
Q2: If the above is true then do I also have to use the same STATSUB(PRETENS) in Loadstep3 considering that CNTNLSUB is present?
Attached are the snapshots for the Loadsteps.
Kindly help.
