Hello All,
can any one tell me how to calculate dynamic stiffness of structure or any component?
which analysis i should carry out?
Hi Rahul K,
Run a FRF analysis.
Hello All, can any one tell me mathematical formulation for structural analysis. static and modal
Refer attached Pdf.
Regards
Rahul R
thank you sir.
dear sir ,
in that pdf only they mentioned the cards for nastran and there is no mathematical formulas to calculate static analysis
Optistruct & Nastran cards are almost similar.I have shared Optistruct user guide in which governing equation are available.
In some of the FEA books you would get formulation of stiffness matrix for different type of analysis.See attached screenshot for static analysis of rod element from practical finite eleement analysis book written by Mr Nitin Gokhale.
for modal analysis is there any formula apart from wn2=k/m?
See attached screenshot.Refer same pdf which i shared earlier for more info.
Hi Prakash and Rahul,
I have done Modal frequency response analysis by giving Displacement as a input and force as a output.
Now my question is, How to calculate Dynamic stiffness of component?
Hi Rahul,
The dynamic stiffness is the frequency dependent ratio between a dynamic force and the resulting dynamic displacement.
You can post-process the same using HyperGraph. Since you are a commercial customer, I would suggest to get in touch with INDIA support team.
we suggest you contactcommercial support hotline by phone etc. here - Commercial Support contact
Dear Prakash,
Thank you for the vital information.
dear sir
nvh analysis means modal frequency response analysis?
i have intervw on nvh analysis can any one share dat file and give me some datas to learn on that
