Is there a way to switch the meshing conditions between the frequency bands? I need to simulate a 5mm radius dielectric hemisphere in 1GHz to 370GHz. My current mesh is adapted to ensure correct results in upper frequency. Therefore, it is taking longer to simulate in-spite of taking advantage of symmetry option. I would prefer to use a coarse mesh at lower frequencies and then use a finer mesh at higher frequencies. Is this possible either in CADFEKO or EDITFEKO?
