where we need to mention the output format in Radioss block format?
I imported the file to Radioss solver but when the analysis is done. I am not able to run the file in Hyperview as I did not mention the output format.
Please help me.
Radioss and optistruct latest version generate h3d file (Output file).
Please check .out file for warning or error.If you are new user refer Radioss tutorial for analysis.
Regards
Rahul R
Hi aditmanurakr,
Please check if any A0# files (eg: <modelname>.A01, <modelname>.A02...) are written in the working directory.
All the A0# files are combined to generate a final animation file in H3D format.
If you have no A0# files, please paste the engine parameters here.
Hi
I'm facing the same problem. I have a lot of A0# files, but no h3d files.
I'm doing the RD-3160: Setting up Multidomain Analysis using HyperCrash tutorial for Radioss.
It's not the first time where I get no errors in the output file but I don't get any h3d file neither.
Thank you
Please share us complete .out file?
Here are the output files,
I had to use Hvtrans to create the h3d files. However, I'm not able to combine all my results files, so I cannot see in Hyperview the complete results (both the coarse and fine meshes).
Alexandre
Did you tried derived loadstep in Hyperview?
Hi Here are the output files, I had to use Hvtrans to create the h3d files. However, I'm not able to combine all my results files, so I cannot see in Hyperview the complete results (both the coarse and fine meshes).
Can you reduce the animation frequency and try again?
