I got the error # 4002 in my simulation and i can not figure out the Problem. My hm-file is atteched to this post. I hope somebody can help me.
Thanks to every viewer.
your example is not really nonlinear (except contact), so NLGEOM isn't the favor. (Try NLSTAT instead).
But you can run the example with NLGEOM, i have maked the following changes:
Material: input a Nu (i have tried 0.3 for both materials)
Geometry: put the parts together (no big gaps between the solids, maybe 1e-3)
Contact: change MORIENT to opengap and SRCHDIS to 0.1 (a little bit bigger then the gap)
Boundary conditions: constrain the upper plate also in X and Z (otherwise there are to many unconstrained dofs)
NLPARM: i have set NINC to 10 and MAXITER to 25
Mario
Hi Mario,
I'm going to try it with your changes. Thank you for the help.
Matthias
the simulation is working now. Thank you!
