@Prakash Pagadala
Hello Prakash,
I am trying to simulate a model with several contacts in Optistruct (Non linear quasi static). The Materials are all linear but with very Little Young Module (40-300Mpa). But there are big Penetrations between sliding parts and the results are not correct.
Contacts with Problem:
ID 16
ID 17
ID 26
ID 27
ID 28
I have followed all Solutions in this Forum but it did not work out. I have tried following Solutions:
-Contact type: SLIDE
-Nlparam NINC increase to 200
-CNTSTB load collector and CNSTB Card in Param (EXPERTNL)
- MORIENT= Opengap
-Additional Clearance: 0.1
-String Value>>Adjust>> Auto
-S2S and N2S (Both tried)
-Track INFINIT and Consli (Both tried)
- Symmetric Contact for IP 16 (2 identical contacts with reverse Slave/Master Component)
- PCONT>>STIFF>>HARD
Because the Simulation takes so much time i share the H3D results too.
Thank you so much for your help
P.s: I should mention that this Model with this Material Parameter has been simulated successfully in Abaqus.
