Plane axisymmetric elements
I'd like to perform a plane analysis of a rotor component. Usually in ansys I used to use Plane182 elements.
PLANE182 is used for 2-D modeling of solid structures. The element can be used either as a plane element (plane stress or plane strain) or as an axisymmetric element. The element is defined by four nodes having two degrees of freedom at each node: translations in the nodal x and y directions. The element has plasticity, stress stiffening, large deflection, and large strain capabilities.
Is there any corresponding element type for Optistruct? I tried to find it in the user help and tutorials but I wasn't successfull. I'd appreciate your help.
Best regards
Jakub
Hi Jakub,
Can you check with CTAXI with PAXI property referenced?
You can get more information about these on OptiStruct help.
0 -
Hi Prakash,
could you correct me if I'm wrong?
Does it mean that hyperworks does not support axisymmetric quad elements like cquadx4 or cquadx8?
I found description of CTAXI and CTRIAX6 but no other elements are listed in solver help.
Is there any tutorial how to introduce CTRIAX6/CTAXI on my own as the elements can not be picked from a list. (so far the only description is available here)
I use HyperWorks v13 with the latest updates and such situation is slightly disappointing.
Altair Forum User said:Hi Jalub,
0 -
Hi Jakub,
OptiStruct can work only with CTRIAX6 and CTAXI for now.
