I need to connect the 3 nodes shown to 1 point. I was doing this using Free Hand morph to move the 2 outer nodes to the center node. This works, but it does not tie the nodes together which is what I need for this analysis. It can be shown in the second screenshot that when loaded into abaqus these nodes seperate and pull apart from each other. Any help is greatly appreciated.
On that same note, is there a way to select two nodes that are in seperate elements and tie them to each other. In another section of this model (where I had to detach elements to create the crack surface) two nodes are detaching that should not be and I would like to merge them back together.
Thank you,
-Clay
