offset of shell elements
i have shell-elements and i assign them an offset.
Mesh/card edit/elements
It works very well.
Now i can´t edit the offset. I don´t now whats wrong because i did it the same way at last. The config is quad4 and the type is cquad4 there are equal to the element.
If i try to edit only one element there pop up the error message:
One entity selected, ignoring coniguration and type specification.
???? The element i try to edit ist exactly a quad4. If i use the 'select tool' (yellow butten: elems) in the card edit panel by using the option by config with config= quad4 and type=cquad4,
the element was selected.
Magic or adjustment in hm?? /emoticons/default_wink.png' alt=';)' srcset='/emoticons/wink@2x.png 2x' width='20' height='20'>
BeMa86,
Please see Altair Support Forum → Modeling and Assembly (Preprocessing) → HyperMesh --> How to delete settings files
http://forum.altairhyperworks.com/index.php?/topic/13434-how-to-delete-settings-files/
and delete the settings files and let me know if the problem persists, please also attach images and your system info, version, HW updates etc at that time,
0 -
Hallo Rahul,
thank you for your answere. I closed Hm and delet the the settings files. Then i opened the model and try it again. It dosn´t work.
Altair Home: C:/Program Files/Altair/12.0
Updates Information:
hwdesktop12.0.110
hwdesktophelp12.0.110
hwsolvers12.0.220
hwsolvershelp12.0.220
sT9.5_hw12.0
Versions:
hgtrans.exe: 12.0.110.40 (Sep 13 2013)
hmopengl.exe: 12.0.110.40 (Sep 13 2013)
hst_ng.exe: 12.0.110.40.500186 (Sep 13 2013)
hstbatch_ng.exe: 12.0.110.40.500186 (Sep 13 2013)
hstdss.exe: 12.0.110.40.500186 (Sep 13 2013)
hvp.exe: 12.0.110.40 (Sep 13 2013)
hw.exe: 12.0.110.40 (Sep 13 2013)
hwmbdmodel.dll: 12.0.110.40 (Sep 13 2013)
hwplot.dll: 12.0.110.40 (Sep 13 2013)
hwplot3d.dll: 12.0.110.40 (Sep 13 2013)
hwpost.dll: 12.0.110.40 (Sep 13 2013)
hwtext.dll: 12.0.110.40 (Sep 13 2013)
hwvideo.dll: 12.0.110.40 (Sep 13 2013)
hwx.exe: 12.0.110.40 (Sep 13 2013)
templex.exe: 12.0.110.40 (Sep 13 2013)
System Information:
Machine: amd64
OS: windows Windows NT 6.1
User: Maresch
Hardware:
Processor: Intel® Xeon® CPU E5-1620 0 @ 3.60GHz (8 CPUs), ~3.6GHz
System Manufacturer: FUJITSU
System Model: CELSIUS M720 POWER
Total Physical Memory: 16384MB RAM
Operating System:
Machine name: RP-TB546
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130708-1532)
Graphics/Display/OpenGL:
Card name: NVIDIA Quadro 2000
Chip type: Quadro 2000
Display Memory: 681 MB
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver Version: 9.18.13.2723
Current Mode: 1920 x 1200 (32 bit) (59Hz)
0 -
I delet all these fils.
Start HM and load the .hm file.
It dosn´t work.
I export a solver deck to Nastran and a Frind can change the offsets. So the Model is ok.
Is there a adjustment, how prevent the card edit option?
