How can I show the units of a graph?
In my attached picture for example I would like to see the units of Y axis which is m/s.
Thank you
Zsombi
aecyd
Certain file types have unit information in them and are automatically recognized by HyperGraph, (like .abf)
For this particular requirement, as a workaround, you can right click on existing axis label (global variable in your case, just click on these letters) > convert units > choose m/s to m/s
What if I want to show the [J] (Joule) from the kinetic or internal energy curve?
I have project called 'cone' so I have a 'coneT01' file without extension and a 'cone.h3d' file.
normally you have to click at the axis label (in your case 'Global Variables') and change the text at the 'Text' tab at the axis dialog !?
Best regards,
Mario
