I got this error but I don't have any rigid in my assembly. I don't know what can be the reason? Would you please help me with that
*** ERROR # 173 *** A dependent d.o.f. defined more than once in rigid element entry. GRID ID = 1377120 component = 1
I got this error as well
ERROR # 1490 *** in the input data: Unexpected continuation card.
Could you share us .out file?
Looks like you have a duplicate dependent node in your RBE. Can you check the RBE which is connected to the above GRID ID?
Share the entire .out file, please
sure here is the .out file
Error is clear.Try remove dependency issue then run.Refer below post as well.
