Error 144, Element has singular strain functions
I'm having problems with the solver:
Error 144: CHEXA Element 70206 has singular strain functions
Please check material data
this error occurs in module stsdrv
the element is a 2x2x2mm (approx.) CHEXA element representing a part of my aluminum hoenycomb core (homogenized as solids using ortotropic material).
the material data is correct and i could run several analysis / optimizations using this material. (only a warning 1553: MAT9 has 1 zero eigenvalues)
the strange thing is that sometimes it works, sometimes it doesnt. when i had the error the last time, i remeshed my mesh (again with a ~2mm size) and then i could run it without problems !?
Can someone explain what this error means and what it comes from? i couldnt find anything useful online or in the help...
thanks !
Michael
Thanks for you answer,
Using a MAT1 works. But since the same MAT9 material model works in another analysis, it must be a combination of the mesh and the material that doesn't work properly....
I double checked the material data, all entries for an ortotropic material are assigned. To avoid conditioning problems, G44 is set to 1000Pa (instead of 0), but this has no influence, as it also didn't work with 1e+8 for G44 (which it was by mistake in the beginning).
regards.
Is anyone has a solution for this issue?
I also have the same problem when running topology optimization with MAT9ORT.
I'm trying to optimize 3D printed structure which has weaker properties in Z axis.
regards
Can you please add the below Debug card and re-run the job
DEBUG,HEPPPRTC,1
Please send me the .out file after running with this card
Regards
Rahul R
normally there is a 'material property check' for MAT1, MAT2, MAT3, MAT8 and MAT9. (see Reference Guide, Material Property Checks)
A warning is produced if any individual mode of deformation has zero stiffness. It seems that is the problem with your material model.
If you have no deformations for this mode, the solver is able to analyse it. If you have deformations, the strains of course becomes infinite.
Try to check your material model.
Best regards,
Mario
