Contact interface
I am trying to setup a crash of a bumper geometry. The bumper consists in 1 curved beam and 2 crash boxes.
I used contact interface type 7 but I am having some errors.
ERROR ID : 59
** ERROR IN PROPERTY/ELEMENT DEFINITION (NUMBER)
DESCRIPTION :
INVALID PROPERTY ID=0,
FOR SHELL ELEMENT ID=2553
ERROR ID : 61
** ERROR IN MATERIAL/ELEMENT DEFINITION (NUMBER)
DESCRIPTION :
INVALID MATERIAL ID=0
FOR SHELL ELEMENT ID=2554
** ERROR TRAPPED : REPORT TO LISTING FILE
ERROR ID : 760
ERROR ID : 194
** ERROR IN HIERARCHY REFERENCE
DESCRIPTION :
-- SURFACE ID : 7
-- INTER_group_8_of_PART TITLE : PART
REFERENCE TO UNEXISTING ID=6
ERROR ID : 119
** ERROR IN INTERFACE SURFACE DEFINITION
DESCRIPTION :
-- INTERFACE ID : 1
-- INTERFACE TITLE : New INTER 1
MASTER SURFACE IS EMPTY
WARNING ID : 692
** WARNING IN SURFACE DEFINITION
Some of them refer material/proprety problems but I am sure that my material and property are well defined.
On top of that I have this image for the parts and I don't know why. (see attachment)
Hi Tiago,
Please make sure that materials and property are assigned to the parts. Check the interface created as the error shows that the master is not selected for the interface.
Please run Model Checker (Quality>Model Checker in HyperCrash) which will list out the errors/warnings in the model.
If you still find any difficulties, please share the model.
0 -
I have done all of that and im having this problems:
ERROR ID : 194
DESCRIPTION :
-- NODE GROUP ID : 4
-- INIVEL_group_4_of_PART TITLE : PART
REFERENCE TO UNEXISTING ID=7WARNING ID : 690
** WARNING IN NODE GROUP DEFINITION
.. INITIAL VELOCITIES
.. DOMAIN DECOMPOSITION
.. ELEMENT GROUPS
.. INTERFACES
ERROR ID : 7600 -
HI Tiago,
Please share the complete out file (_0000.out)
0 -
HI Tiago,
Make sure that for all components PART card image is assigned. If you have any rigids, also make sure that no PART card image is assigned for rigids.
If the issue persist please share the model file (_0000.rad)..
0 -
I have seen other posts with this problem and I have tried to assign card image but I dont know how to do it in HyperCrash
0 -
I have been 3 days with this problem... Thanks a lot. RADIOSS is running. I let you know if I have good results
