Simlab and Topology Optimization
three questions about the topology optimization with simlab:
1) does simlab support postprocessing topology optimization results?
2) I cant find any manufacturing constraints, like mindim in simlab? are they not available?
3) I set up a topology optimization in simlab. it works fine but i cant start the optimization directly from simlab. why the function is not activated? (see pic)
Thank you
Rahul,
thank you for you replay. I still have a problem with the import. Can you tell me how to import the optimization results in simlab. Is it possible to set the density ISO in simlab?
This is the simlab.bat:
@ECHO OFF
REM ************************
REM SimLab License file
REM set ALTAIR_LICENSE_PATH=
set CAE_HOME=%~pd0
call '%CAE_HOME%\vp_init.bat'
start '' /B %SL_START_CMD% %SL_START_CMD_ARG% %*
Requesting you to share Vp_init.bat file.
C:\Program Files\Altair\14.0\SimLab14.3\bin\win64
Rahul,
Vp_init.bat as requested:
@ECHO OFF
if defined STS_INIT_DONE goto :EOF
set STS_INIT_DONE=TRUE
REM CAE - Application
if not defined CAE_HOME set CAE_HOME=%~pd0
set PATH=%CAE_HOME%;%PATH%
REM Unity Variables
set HW_PLATFORM=win64
set ALTAIR_HOME=%CAE_HOME:~0,-10%
set HW_ROOTDIR=%ALTAIR_HOME%
set HW_UNITY_ROOTDIR=%HW_ROOTDIR%\unity
set PATH=%PATH%;%HW_UNITY_ROOTDIR%\bin\%HW_PLATFORM%;
REM ***************************
REM SimLab specific parameters
set VP_SCRATCH_DIR=%TEMP%\SimLab\SimLab 14.0 64-Bit\Temp
if not exist '%VP_SCRATCH_DIR%' mkdir '%VP_SCRATCH_DIR%'
REM ******************************
REM SimLab Project File Directory
set STS_PROJECT_LOC=%TEMP%\SimLab\SimLab 14.0 64-Bit\ProjectDir
if not exist '%STS_PROJECT_LOC%' mkdir '%STS_PROJECT_LOC%'
REM SimLab License Path
if not defined ALTAIR_LICENSE_PATH set ALTAIR_LICENSE_PATH=%CAE_HOME:~0,-23%\security\altair_lic.dat
REM Parasolid Import
set PATH=%CAE_HOME%\parasolid;%PATH%
set P_SCHEMA=%CAE_HOME%\parasolid/Schema
REM *************
REM Step Import
REM *************
set PATH=%CAE_HOME%\step;%PATH%
REM ***************
REM CAD Translator
REM ***************
set PATH=%CAE_HOME%\sl_cad_translator;%PATH%
REM ProE Install Path
SET VP_PROE_HOME_DIR=%CAE_HOME%\proe\wildfire3.0
set VP_PROE_CMD_DIR=
set VP_PROE_CMD=
set PATH=%VP_PROE_CMD_DIR%;%VP_PROE_HOME_DIR%;%PATH%
set VP_PRO_PAUSE=0
REM Catia Install Path
set SL_CATIA_INSTALL_DIR=
set PATH=%SL_CATIA_INSTALL_DIR%\win_b64\code\bin;%SL_CATIA_INSTALL_DIR%\win_b64\code\command;%PATH%
REM CATIA Step Approach
set CATIA_SCRATCH_DIR=%CAE_HOME%\Temp\Catia
set CATIA_CMD=catia.bat
set PATH=%CATIA_SCRATCH_DIR%;%PATH%
REM CATIA Direct Access
set SL_CADNEXUS_DIR=%CAE_HOME%\cadnexus\CAPRI
set CATEnvCAPRI=
set PATH=%CAE_HOME%\cadnexus\3.20;%SL_CADNEXUS_DIR%\lib;%PATH%
REM CATIA Variables for SimLab
set IMPORT_CATIA_PUBLICATIONS=TRUE
set SIMLAB_READ_CATIA_PART_NUMBER=FALSE
set SIMLAB_RESET_CATIA_FACE_COLOR=FALSE
REM ************
REM UG Import
REM ************
set SL_UG_INSTALL_DIR=
set PATH=%SL_UG_INSTALL_DIR%;%PATH%
REM JT Import Parasolid
set PATH=%CAE_HOME%\jtopen;%PATH%
REM Parasolid Translator
set PATH=%CAE_HOME%\parasolidtranslator;%PATH%
REM ***********************************
REM UG Attribute ug-open=1 cadnexus=2
set SL_ATTRIBUTE_READ=0
REM H3D Reader
set PATH=%PATH%;%CAE_HOME%\HW_HM\HW-13.0.110\io\result_readers\bin\win64
REM Clean up Older Version Help Docs
if exist '%LOCALAPPDATA%\Trolltech' rmdir/s /q '%LOCALAPPDATA%\Trolltech'
REM It Creates element fast
SET STS_FAST_CREATE_ELEM=TRUE
REM SimLab UI Related Variables
set UNITY_SL_PROJECT=1
set SHOWORHIDE_DESELECT=0
set UPDATEGRAPHICS_FLAGBASED=1
set SL_DIALOG_VALUES_PRESERVE=true
set UNITY_SELECTION=1
set BROWSER_BLUE_TEXT=1
set UNITY_DIALOG_ANIMATION=0
set SL_SAVE_SESSIONFILE_IN_DISC=true
if not defined SL_ENABLE_SCRIPT SET SL_ENABLE_SCRIPT=1
REM set SL_EXPORT_ABAQUS_QUALITY_FAILED_ELEMENTS=TRUE
REM set SL_FLUENT_INTERFACE_GROUP_METHOD=TRUE
set SESSION_TESTING_COMPARE=false
REM set STS_N_KGF_UNIT_CONVERT=FALSE
set SKIPUPDATES_CALLBACK=TRUE
set ENTITYDISPLAY_IN_LINEEDIT=20
set SL_SHOW_AUTOMATION_SESSION=false
SET SL_START_CMD='%HW_UNITY_ROOTDIR%\bin\%HW_PLATFORM%\hwx.exe'
SET SL_START_CMD_ARG=-sf plugins\simlab\resources\exec_icons\splash.jpg -v SimLab_V14.0 -client simlab
CALL '%CAE_HOME%\STS_solver_setup.bat'
Rahul,
a additional question. You said Simlab supports post processing of Topology Optimization results.
I try this but with no success. I have set up a topology optimization in SimLab, afterwards I export it and start optistruct. Then i tried to import the h3d_des result in Simlab.
Simlab shows the model, but no results. where is the bug?
Thank you
If possible could you please switch to latest vesrion Simlab 14.3. or
The STS_solver_setup.bat contains the solver path to solve while solving.
If this is defined then optimize should be enabled
Did you try loading h3d file in Hyperview.HV is the recommended tool for post processing.
Yes Simlab support post processing of Topology Optimization results.By the way which version of Hyperworks simlab you are using?
Also Hyperview is the recommended tool for post processing.
See atthached screenshot for mindim.
By default it should take Optistruct solver for analysis & optimization.If possible please share simlab .bat file.
