I would like to optimize 1 D Truss (Sizing Optimization), I do not know, how can I define the design variable in HyperWorks (in OptiStruct), for example, cross-sectional parameters (R, a, b, h). or Length...
thanks for your help
Design Variable
• The parameters, properties, or elements that OS can change to achieve different responses
• Prototypically usually an entire part or a significant part feature
• Represented in a trade diagram as the area or n-dimensional volume of the plot
Please find the attached images to help you out.. May it will be helpful to you.
Pritam Prakash
You can link PBEAM or PBEAML (if you are using 1D elements) as a design variable in Size panel, you can either change the cross sectional area or moment of inertia to change the cross sectional parameters.
